On two journeys now, the heater fan refuses to work, and at the same time, the rear window demister won't switch on. Or if it does, it'll only be for a second, then switch right off. The fuses for each are fine. Now the days are getting colder, and I'm driving more, this is a huge concern.
There's presumably power to the climate control box under the dash, as I can hear the flaps being moved across the heater matrix when I adjust the temperature control. Just no fan, and no rear demister. Anyone know the common link?
