Yes BX fans, after 2 days and 450 miles the water pump threw its toys out of the pram! Until repairs can be made, I have been relegated to 1989 LHD blue 2cv. Just driven 100 miles, I felt every one of them on a dark, cold rainy M4. [;)]
On the plus side, 2cv is working, and there is no coolant pissing out anywhere. [:)]
Project BX Broke already
jonathan_dyane
Jon
Ah, the timing belt, water pump and a clutch were most definately pencilled in for a week Saturday when I'd arranged to borrow a ramp at my mate's garage for the day.
As we were short of time, and a car, Mr Louis Barbour is carrying out the water pump/timing belt, but as I turned up as his place unannounced, all he could give me was the 89 LHD 2cv which he assures me is up to the job, certainly it did Gt Missenden to Swindon via Gerrads X no problems. I actually very much like 2cv's, and they are in their purest form in LHD. What I had forgotten was the wind noise etc. Still, this one seems to go very well indeed and didn't give me any cause for concern this evening. I'll drive it up to Birmingham tomorrow. Its good for it.
PS Dave, your 205 doesn't actually work but the 2cv does.
jonathan_dyane
Dave Bamber
NiSk
tomsheppard
tomsheppard
Sorry to hear it Jon. Louis will doubtless make a good job of it. Often the way with a recommissioned car, though. I remember being told by an independent specialist that if aBX had been sitting for three months or more, walk away. We are made of sterner stuff but this is one to be philosophical about; after all, the car should now last a long time.
oilyspanner
You have perhaps had a little bad luck there Jon, still once you finally sort the thing it should last a few years without trouble, my own BX Ebay car is just about coming together, this week I replaced rear arm bearings, one rear caliper (inboard piston siezed totally)repacked rear wheel bearings (grease turned to cheese, moved away from races!)got the ventilation fan working properly(Thanks Tomsheppard) and am currently running Hydraflush, I also took the opportunity to lower the ride height as it was sitting way too tall. As an extra I have also fitted a scoop on the bonnet forcing cold air directly onto the intercooler.still havent had the courage to play with the fuelling/wastegate though. ah these project vehicles.
Stewart
Stewart
