My 98 XM 2.oi CT turbo auto accellerates suddenly very slow. especially from stop. I have changed spark plugs and air filter and cleaned secondary airvalve. The fuel/ignition syatem tell-tale light comes on when starting for about 10 seconds and than dissapears. No alarms showing.
Once the car has a bit of speed I don't have this problem any more. Kick-down works OK.
Any suggestions where to look?
Reduced accelleration
activa
I think it could be lamda sensor or problematic catalyst / exhaust ...
Dimitris
http://users.otenet.gr/~activa
Xantia Activa Turbo 2.0
Dimitris
AndersDK
citrofan
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AndersDK</i>
If a turbo car suddenly feels slow, then suspect a stuck open wastegate valve.
As you get the ECU fault lamp on, you can get the fault code read out. It may show a faulty sensor on engine.
Thanks Anders,
Where can I locate the Wastegate valve?
Thanks Anders,
AndersDK
