Ermmm, the title just about sums it up really. I've got an intermittent fault on my Xantia where I can hear the flasher relay working overtime (double speed) while I'm driving straight ahead. There are no visible signs from outside the car that anything is wrong - no indicators flashing hideously, or anything like that. So I'm street legal.
Everything carries on working fine when I use the left or right indicators in the normal way - they come on, at the correct speed, and cancel correctly. It's the same with the hazard flashers, everything works OK. Then, as soon as I've completed the turn, it's back to the old tickatickaticka again. (Unless it's gone away - I <i>said </i>it was an intermittent fault.)
All bulbs are OK. Any thoughts? Please tell me it's not the indicator stalk switch again! I had that replaced about four years ago, and a right performance it was too.
Cheers
Flasher Relay - tickatickatickatickaticka.......
arry_b
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MW</i>
Errr.....
Errr.....
TheWorker
ItDontGo
MW
nick
It is possible to dismantle the indicator switch and bend the contacts in a bit. I did this on my Xantia about 3-4 years ago and its still working fine. Getting the switch back together was the problem, sort of like one of those Chinese puzzles. I had to assemble the bits loose on the table then slowly slide the outer casing of the switch back down over the top without disturbing any of them.
wrinklet1
Panjandrum
xantiav6
- x 3
The problem is due to copper dust from contact wear in the switch. The dust gets trapped in the grease used to lubricate the contacts, making it a bit conductive.
You can also fix the problem (for a couple of years anyway) by changing a resistor in the flasher unit. see more information in http://www.andyspares.com/discussionfor ... rms=xantia
