Are they the same? J Reg 1.6 Athena and a 1997 1.9 TD Xantia SX?
To remove deep corrosion/rusted holes from the fasce of s disc I put a medium/coarse sheets of wet snd dry between disc and pad, works a treat. Apart from making sure you maintain minimum thickness any problems with this method
Incidentally does anyone want a working ABS ECU for a BX? My dad will just want postage. Will post make P/N if any interest
BX and Xantia rear disks, thr same??
JohnD
- x 72
oilyspanner
Kowalski
