Air bag warning light
Post Reply
johngreen
My Cars:
Post by johngreen »
Hi Guys,
Can anyone tell me if it is possible to cure the illumination of the side airbag warning light without goin to a dealer??
Cheers John ( the car is a w reg 406 coupe 2 litre)
PowerLee
My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2
Post by PowerLee »
Hi
Check the connector plugs under both the front seats.
Orange is for the seatbelt pretensioners, Ive no idea what colour the side airbag plug is?
Make sure you have the radio code & shut the alarm system down then disconnect the battery first & wait 10 minutes.
Unplug the connectors & clean them with WD40 or similar, make sure the metal terminals are a tight fit together & plug them back together.
Reconnect the battery & see if this sorts the light out, if not then it is a trip to a main dealer or a Citroen / Peugeot garage.
Post Reply
