<font face="Tahoma">Xantia 1.9 TD 1998, LX, facelift. 142K miles
Car has anti sink so stays up over night.
when it's turned on in morning the front lifts up straight away but the rear lets all the fluid out and sinks to the bottom!
Then about 1-2 mins gradually creeps up and up , then with one mighty effort reaches the top only to sink about 5-7 cm.
Sometimes it just doesn't even bother to lift up and I have to drive off with it trailing until it lifts up halfway down the road. [:(!]
what would cause such a phenomenon? as self levelling works fine front and rear. <font face="Tahoma"></font id="Tahoma">
Had the car almost a year now and it's always done it.
I'm only the 2nd owner</font id="Tahoma">
she's going down lads
mseymour
Does the suspension seem otherwise fine once it's pumped up?
I would suspect it doesn't always raise up because the height corrector is a bit sticky. I think I'm right in saying the rear anti-sink valve should be suspected.
What condition is the LHM? If it's anything other than perfect I'd drain and flush the system before refilling
aboutyeabig
nick
aboutyeabig
jeremy
The car has to sink before the anti-sink is needed. generally the fronts sink after the rear - so this may be the answer to your question.
The anti-sink sphere is there to top up pressure once the anti-sink valve opens - so it looks like your rear A/S sphere has gone - not the valve. Full instructions for changeing are somewhere on this site.
jeremy
jeremy
wrinklet1
Hi, I think it proove worthwhile, you getting under the car with Gunk in hand, give the height correctors front and rear a good going over with gunk, and while your at it, any other parts connecting together making sure you move the height adjuster inside the car a good few back and forth movements to loosen any crud. Then powerwash under neath the car giving it a good going over. Now the best bit, Gloves on, and give the height corretors a good greasing NOT oil. Paste the grease all over including the connecting rods. I have done this with my Xantia and it made a world of difference, make it a yearly task and the ride wil be perfect.
Regards
Paul
Regards
Paul
jeremy
wrinklet1
Kowalski
rory_perrett
