Xantia slipping out of 5th
CommY
Unread post by CommY »
It only slips out of 5th when the revs are dropping and the car is going round a corner.
There is a fair bit of movement on the engine mounts (quite a lot)
Could the engine mounts cause this or is it knackered selector forks?
Any other suggestions.
Robin
Unread post by Robin »
Start with the mounts. I am not aware of this being a Xantia fault so hopefully the problem is not gearbox related. R.
Dave Burns
Unread post by Dave Burns »
I'd look at the gear lever to box linkages for stiff joints.
Jumping out of gear on the overrun can be a sign of a worn box, but not from flexing of the engine/box mountings, that can't influence the gearbox internals to do things like jump out of gear, except via problematic linkages.
Dave
