When I put my '00 Xantia HDi 110 in the lower suspension position, and then go back to normal position, front goes up, but rear doesn't.
I've tried several times, waited a long time and pushed the acelerator , and the rear didn't go up.
Now, if I change to the next position (higher than Normal), it goes up right away, and then, going to Mid (normal), it stays OK.
More info: Riding seems OK, spheres are all new; LHM has been changed 7Kmiles ago. Suspension is non-hydractive, 6 spheres (4 + ACC + AS).
Can yu imagine why this happens?
Xantia HDi not rising from LOW to NORMAL position
harryb.48
Hi T-Bird
My xantia behaved exactly the same after I bought it ,it was just a rusty/sticking rear height-corrector.
When you move the lever to normal the override mechanism will just not activate due to resistance in spring etc,but when you push it further,i.e. to next setting ,it will suddenly overcome this and raise the car normally
A good clean-up and oiling freed mine up and it was subsequenly greased to keep it operational- has been ok since.
Good Luck
On reflection having seen your car`s age/mileage it`s hard to believe that rust has affected the HC so soon but then it is very exposed.
Maybe others can confirm or refute this , but I still think the problem lies in this area.
Good Luck
Thunderbird
harryb.48
harryb.48
It`s easy to find - just get underneath with car on ramps or axle stands and look to the centre of where the rear axle would be and if you get a helper to operate the control lever you will see exactly what`s going on.
there is a picture of the HC itself at : http://www.andyspares.com/discussionfor ... IC_ID=7262
IT`s attached to the rear anti-roll bar with a clamp,but it`s the mechanism operated by the control lever(override) which is likely to be causing your problem.Nevertheless the whole hc will likely benefit from a clean and lube.
Regards
Regards
DoubleChevron
