Renault Megane 2.0 RXE manu' fitted cd tuner
greenmamba
Unread post by greenmamba »
Does anyone know where you can buy a replacement cd tuner for a Renault Megane. The Cd tuner is a philips Radiosat 6000 22DC479/62.
My one does still work, except that it will frequently decide to turn itself off, and on again, whenever it feels like it. This only happens when playing CD's on it....(it appears anyway so far). It would be nice to fix this problem as I would like to still use the steering column remote stalk and no other cd player wil be compatible.
Many thanks in advance.GM.
reblack68
Unread post by reblack68 »
Ebay's a good place to look, there are always several on there.
I don't know if it's a coded unit but make sure you get the code if it is.
Stuart McB
Unread post by Stuart McB »
This sounds as though the power to the unit is not getting through all the time. Remove the unit from the car and check that the multi plug hasn't come apart in the rear of the unit.
