Xantia steering column top bush.
paranoid
Unread post by paranoid »
Can anybody give me advice about changing the above, as I have a bit of a knock coming from the wheel when wiggled up and down, side to side.
Tightening the nut behind the wheel cured it for a while but it gets worse after a while.
OR
Could it be the nylock nut coming loose, its only happened sine I took the steering whell off to do the dash lights ?
oilyspanner
Unread post by oilyspanner »
I had a similar problem on a BX which turned out to be the lower bearing which had slid down the shaft, tapping it back up solved it.
Stewart
paranoid
Any pointers how to do it?
paranoid
Just took steering wheel off, definately the top of column, cit dealer said i need the whole column piece £100 does anybody know a cheaper alternative, the MOT is due in 2 weeks[V]
oilyspanner
Plenty in the breakers around here
Stewart
