Hi I need to replace the glow plugs on my kangoo . the air filter is in the awy and I can't see how this is removed. any advice please. Also does any one know where i can get a workshop manual.
Andre
Kangoo
lochar_Lady
andre
beezer
Not wanting to spoil a sale but the air cleaner housing is removed by unclipping the top and taking out the element then unscrewing the duct and removing that (a twist either way takes it out from the radiator end) then you go down behind the engine to remove nuts from the housing then the top nuts and you've done it.
You can use the Clio manual for most Kangoo jobs but the Russek is a gem.
