That is how long it took to fit 4 new tyres to my ZX. 2 hours!
Some bone head had stripped the thread of one of the wheel bolts on the drivers side front, so the mechanic had to re-tap the thred, half way through, his Snap-on re-threading tool decided to Snap-off! leaving one half in the hub. That ment a strip of the hub to have it drilled out, then retapped > thhose bitss are hard ya know!. Then while rebuilding he noticed one of the caliper bolts had snapped, and to top it off the garage had a power cut for about 5 mins while one wheel was one the balancing machine!
Ahh the joys of Citroen ownership! - still only cost me £60, and they worked through till gone 6, so can't grumble
30 min job? It's a Citroen make that 2 hours!
LeFrog
rossnunn
NiSk
You're lucky he didn't charge you for the snap-on! Most garages would! And you car is not alone in breaking wheelbolts - I just finished changing a bottom ball joint on a mates Audi 80, tightened the wheel bolts up with a MANUAL wheel brace and ended up with half a wheelbolt in it! Same procedure - out with the HS drills, luckily the stud extractor worked this time - otherwise om my daughters Passat (same design) we must have changed at least a half dozen broken wheelbolts over the years.
//NiSk
//NiSk
tomsheppard
Nisk, in this country, Snap-ons have an unconditional lifetime guarantee. Break it and it gets replaced. Free of charge. A very kind friend once enquired of me what I would rate as a good spanner. I answered him that I rated Snap-ons as jolly good tools. To my delight and surprise, he bought me a set for Christmas. I've never needed that guarantee and they are now ten years old.
Should one get mislaid, I become like a teething infant until it is found, cleaned and safely returned to my toolkit!
Kowalski
Not that I want to start a holy-war about tool brands, but...
Snap-on are very over priced, there are other manufacturors who produce tools that are as good with the same lifetime replacement guaruntee but at a lower price. You can argue that snap-on are better quality, but I know of better quality tools at better prices.
Compared to cheap rubbish, Snap-on are good quality but if you compare them to decent tooling (Britool, Elora, Facom, Sykes Pickavant and numerous others) they are nothing special at all.
Stuart McB
Always remember have to have a tap 'spark eroded' out of a diesel cherry picker on hire once. Night shift came on, flat tyre. I know, not much to change all going well untill 'SNAP' as above. The stud had broken so far down the bl**dy hole we couldn't get at it with the drill and bit so we had this new piece of kit and I tell you the thread looked like new. No re-tapping required. 20min job for 2 turned in to 4 hours in the middle of winter at night. Ah thoes were the days.
bxbodger
ItDontGo
I remember pulling a stud out of my mini's hub right before I had to go to work. I thought 2CVs, AXs and the like only have 3 nuts/bolts so what the hell. I think I drove around for about a week before I went the scrappy and got a stud. I'm still here and so is everybody I drove past. [I can sense I'm about to get a telling off though]
