Saxo Brakes
Glo
Saxo Brakes
Unread post by Glo »
Does anyone know what the torque should be on the rear hub,as i've just fitted new brake shoes,i've had lots of problems,but i've sussed it now,only problem being i have no manual to tell me what the torque should be. Thanks in advance!
Stuart McB
Unread post by Stuart McB »
I found that as tight as you can go with out going mental on a long bar is about right, if you don't have a torque wrench. This based on 17 stone fatty with deep deep deep pockets. Never had any probelms.
blueboy2001
Unread post by blueboy2001 »
I've no Haynes but they don't need to be mega tight. Don't forget to stake the nut.
Glo
Thanks for that guys,it was the torque on the bearings? that i meant-does that make ant sense?
madasafish
Unread post by madasafish »
My Hayenes: 140nm, 103lb/ft
