zx 1.9d 1st gear selection
I've noticed that first gear can be a bit of pig to select on my ZX - just put it down to being a characteristic of the breed. I've cleaned and lubed the linkages etc and the change is really slick apart from selecting 1st gear when stationary. Recently I drove a BX 1.9d (j reg) and noticed that first gear selection was perfect. Do I have a problem with my gearbox and if so - any suggestions, Guys??
Ron
Ron
- Contact:
Not really sure, could be the linkages with play in them. The ones in my 16v are shot along with my clutch. Bite point is on the floor and i barely managed to get it into any gear at junctions coming into work today, had to do all the other changes without using the clutch. Going to see if theres any more adjustment left in the cable at lunch
- Contact:
Do you have the same problem on engaging reverse? If so it suggests that this is a clutch problem rather than worn synchro rings? Is the clutch clearing cleanly and any problems in engaging third from fourth? Usually a worn box throws this problem up first. It is unusual to have synchro problems on first gear. If the clutch is on its last legs the springs will allow the driven plate to tip and make contact unevenly thus creating a notchy selection.
- Contact:
- Contact:
