rust treatment
mseymour
rust treatment
Things are starting to go a bit rusty round the back end of my 96 xantia estate. The rear suspension assembly is particularly bad. I was going to take the bumper off, get it steam cleaned then clean up the flakey stuff and treat with waxoyl... But is that the best thing to use or even the best thing to do?
bxbodger
Catch it while you can- anything's better than nothing!
Pressure wash all the crud off ( you can use one at the local car-wash ) , have a good poke around with a screwdriver to make sure its all solid, then wire brush what you can get to and give it a coat of rust-convertor. Follow it with a coat of red primer and then some wax-based treatment; waxoil or similar.
Make sure you pressure wash the underside of the car two or three times in the winter, and there should be no further problems.
As an aside, in the current issue of "car mechanics", theres an article on Saxo's of a similar vintage suffering from severe corrosion problems....could this be Citroens Lancia era????
mseymour
madasafish
Personally I would NOT use waxoil. It tends to sit on top of rust.. which continues to fester underneath. I use a Dinitrol spray - which id far most liquid and penetrates far better and then sets to a soft type of greasy cover. Seems to prevent rust far better: kept on using Waxoil on Peugeot 106 suspension uprights and had to do it evry year as it washed off. Dinitrol lasts 3 years to date:
goose
speaking form experience as a panel beater by trade i wudnt touch waxoil its crap to put it so bluntly. to beat rust grind it out if bad or use a wire abrasive to get it off the surface. then if underbody use shultz! its a tar like thick matireal whick will not let rust thru and is used everytime when sealing a job in work!!
i did the whole under body of my zx with it and i have had no rust what so ever. ive also done realatives and a mates lancia y10T and ive had no complaints. remember to mask up vital parts i.e brakes and wiring!!
mseymour
uhn113x
- x 3
My two penn'orth:
I use Fertan as a rust converter - it is tannic acid based; better than phosphoric acid. Not cheap, but their website is worth looking at - used on ships and stuff.
I must take slight issue with the remarks about Waxoyl - it penetrates fine if you thin it with white spirit. I don't use it now - I use Shell Ensis for hollow sections; similar but more 'sticky'
It is used for spraying on machinery that is left outside in winter.
Some folk use a mixture of chainsaw oil, engine oil (new!) and white spirit.
Goose - do you mean 'Schutz'? I use this for painting exposed bits - I often mix it with Ensis as well. You deserve a medal if you have stopped a Y10 from rusting [:D]
Oh dear - that reminds me - DS ready for annual treatment - full day's job [:(]
Stempy
goose
uhn113x
- x 3
<b>Schutz!</b> - see http://www.midwayautosupply.com/manufac ... dercoating
Schutz is a trademark name. Do a google for 'shultz' and the only thing you will find are hits for 'George P Shultz' (who he?) with nary a mention of undersealing!
All that I have bought says 'Schutz' on the tin.
Apologies for being pedantic, but if anyone is searching the www for further info, they do really need to search for the right thing!
uhn113x
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Forth</i>
Isn't he Snoopy's dad?
He may very well be, as no-one seems quite sure whether he was Charles <i>Schulz</i> or <i>Schultz</i>, not even Amazon! [:D][:D]
From what I remember of seeing Peanuts, he was 'Schulz'
