After changing the "O" ring on the little plastic cup underneath the accumulator on my xantia, started the car and both red lights continue to stay on and moving the height position lever has no effect.
Whats happened here? All suggestions welcome.
can't get it up!
JohnD
- x 72
porgy
Dave Burns
- x 3
Sound's like you may have got air into the hydraulic pump, if so it now need's to be primed, take the intake pipe off at the reservoir and pour clean LHM down it to fill it and the pump, replace it on the reservoir before starting, and have the pressure release screw open.
Be very carefull not to get dirt in it.
Don't keep on running the engine unless you can be sure the pump is working, look in the reservoir for return flow.
If the power steering is seperate from rest of system start turning the steering as the engine start's.
Power steering is seperate if there are two steel high pressure pipe's coming from the top of the hydraulic pump.
Dave
Dave
porgy
Dave Burns
- x 3
Hang on there George, if there is indeed a return flow then the pump is already pumping, the priming of a pump is only done to get pumping started, if it is'nt pushing fluid out because it's got air in it then nor will it suck fluid in to continue the cycle.
You don't say what year your car is, wether it has seperate power steering or not.
If as you say there is a return flow and yet no power to the steering then it must be a 93/94 car with a flow distributor valve.
With this particular set of circumstance's I would put the problem down to having disturbed something on the regulator, hence no pressure build up, and the return flow.
Let me explain what I mean by seperate power steering.
On later car's the hydraulic pump is basicly two pump's in one housing, sharing the same (suction pipe) intake and drive method but with two totaly seperate high pressure outlet's.
The outlet for the steering goes directly to the steering rack and from there back to the reservoir.
This situation on a later car WITH a return flow to the tank, the power steering would be unafected.
Early model's will only have a single high pressure output and will power the entire hydraulic system, this setup require's a flow distributor valve which favour's the braking circuit for obvious reasons.
Dave
Dave
porgy
Dave Burns
- x 3
porgy
Thanks Dave for your input.
I've loosened and tightened the screw several times now. It's never been removed completly.
This heavy steering has confused me, as really except for the pump it is a seperate system from the suspension. I consider okay so the power steering has an airlock. But the fluid return from the regulator is working fine ( I removed the tube at the resevoire and watched this happening)so the fluid must be reaching the regulator in the first place.
When I replaced the "O" ring everthing went back correctly (I had undertaken this repair before at 110,000 miles).
I've covered just over 200,000 miles with this motor and undertaken many repairs and servicing, but this latest problem has me baffled.
George
George
Dave Burns
- x 3
Your not the only one that's baffled now George, what's the situation with the brake's and suspension, are they up to speed.
You could try loosening the steering output union on the pump to see if that expells any air or oil, could be messy though.
Could also try shoving a trolley jack under front subframe, take some of the weight (not all) off the tyres and give the steering a workout.
Don't suppose you are using the car at the moment in this state.
Dave
Dave
