1997 Renault Clio Phase three leaking sunroof
The PIT
Unread post by The PIT »
Our local dealship claim that the fault is due to the securing bolts becoming striped so the whole frame becomes loose. The only solution they say is a new complete sunroof.
Does anyone know whether this is true or not?
Also where are the drainage holes as I can't see any and the rain goes striaght into the central roof console.
Dave Burns
x 3
Unread post by Dave Burns »
Unless one actually see's the problem it's difficult to advise, but there may be other solution's, one may be to drill out the offending thread and insert a captive nut often refered to as a "pop nut" because it is similar in action to a pop rivet.
Or it may be possible to drill out and re-tap with a larger diameter thread.
Dave
