I tried this on the air con forum but no luck so far, I have a P reg Xantia 1.9 td + air con, the blower fan is running very slow, in fact hardly turning at all no matter where I shift the slider control.
Any ideas as to whats the matter with it?
Blower fan hardly turning at all
AndersDK
np
Same on mine.Although sometimes it wont work at all,or it will work & then stop.Or just run slow.Under the glovebox,remove the carpet to get to the blower assembly.Have a look at the wires.Theres a thick red wire,about 4" long,that connects to the unit.On mine,both ends of the wire at the connections have melted slightly.When mine plays up,i just give the wire a wriggle,& then it works fine.Untill the next time.I`m going to try & replace it at the weekend.Hopefully that will cure it.
Has anyone else had this problem?
