Bulb change on Dash.
user_3150
- New User
Just a quickie. My Haynes is packed as we are waiting for a date to move house and the bulb on the top row of the ventilation controls has blown. How do I get to it? Cheers.
xantiav6
- x 3
I had an A/C control panel apart a few months ago and I only remember one bulb. But to get to it, you <ul><li> Remove the radio surround (a couple of screws at the bottom, and ease out the clips at the side)</li><li>Remove the screws holding in the control panel</li><li>Ease out the control panel (be careful not to stretch or kink the cables)</li><li>The top cover unclips from the control panel and the bulb holder can then be unclipped</li> <li>Don't attempt to unclip the front of the control panel, as the rubber strips behind the slide controls are nearly impossible to get back in</li></ul>
Good Luck.
Good Luck.
user_3150
- New User
xantiav6
- x 3
Vert Galant
Alec, for pictures, see http://xantiaclub.net/onderhoud/article.php?id=5
Let me know if you need a translation of the description given there: its a Dutch site.
