94' 306 Headlight Replacement?
easterroad
Unread post by easterroad »
Hello,
My MOT is coming up and I have a fairly large crack in my 306 XTDT's headlamp lens.
Is it possible to just change the lens or does the whole unit have to be replaced?
Also if I do this myself how do I check alignment afterwards?
Thanks for any advice on this!
kevin
Unread post by kevin »
I am fairly sure you can change the lens separately, check on this site if you can buy the lenses separately.
solara
Unread post by solara »
Yes, you can buy lenses separately.
Most MOT garages can adjust the lenses on the spot for nothing, some charge a few quid.
easterroad
ok, many thanks for the info, will have a go at replacing the lens later this week.
