Cambelt and other belts replacement
Thunderbird
Unread post by Thunderbird »
Should all the engine belts besides the cambelt be replaced simultaneously?
Robin
Unread post by Robin »
I would replace them all together simply because of the trouble you have to go to getting there. Convenience rather than any mileage requirement. R
Stuart McB
Unread post by Stuart McB »
Must agree. Had the cam belt done on my Xsara not too long ago, had the power steering / alternator belt changed at the same time. Look at it this way, they're bound to be original so if your coming up to the cam belt milage change those belts have done the same distance.
