Have collected a pair of hubs from Berlingo (to do brake upgrade). Whilst burning the midnight oil preparing everything, I removed the old disks and noticed that there seems to be quite a bit of play in the bearing.
It rotates freely enough, but the centre section to which the disk fits to has some lateral movement.
Should there be some play in this bearing, which will be reduced when bolted back together with drive shaft in etc, or am I best replacing it. If so is there a 'preferred technique' to remove the bearing.
Weather permiting will jack up car and compare with existing hubs. To consult Haynes book of half truths this evening...
Bearing play in Hubs
Kowalski
Play in bearings is generally not a good thing. Actually thats not true, play in bearings is NEVER a good thing.
Generally with wheel bearings there should be no play at all once assembled. Some wheel bearings need a pre-load on them to avoid play, but the Berlingo ones should have no play (or very little).
rashmore
Stuart McB
I agree with what rashmore is now saying. Just b***ck them up tight. Over the years I've worked on 20k ton (not tonne) presses and heavy plant this sort of thing popped up all the time. Unless it's a thrust bearing, taper roller or oil light bush of some type the side load from doing up tight should be enough to hold it all together and not interfere with the bearing it self. But saying that I've seen some real big BANGS on those presses and plant in my years. As the wife say's best move I ever made getting out of that game [:D].
Kowalski
rashmore
John F
Rashmore, a tip I used to give apprentices for setting taper roller bearings without preloads was to get a box spanner/socket without a cross bar/Handle and run the nut up to the face of the bearing inner so that you couldn't turn the tool any futher and then to fit the handle/cross bar and put (according to bearing size) between 1/8 and 1/4 turn on. If it was a wheel bearing, grab the top and bottom of the wheel and give it a good "shake" to settle everything; undo the nut at least two turns and then without cross bar/handle to wind the nut against the inner bearing once more and lock the nut with a counter nut, tab washer or split pin.
oilyspanner
Stuart McB
John F. You sound just like my old gaffer from when I was a tea boy. Sorry meant to say apprentice. We always got the s**t jobs for the first 3 years at least or untill another lad started and then you were the boss. Thats one of those pices of advice that I carry around in my head as though it was yesterday, along with stuff (god rest him) that my Dad told me a bout girls and how not to get trapped by their evil and yet sexual ways. Funny how I listend to the gaffer about pre loads but not me Dad.
