RT4 Citroen c5 2008 Black display.
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
sttoper
Unread post by sttoper »
The other day, a black screen appeared on the RT4 HDD radio, and only an orange light above the SOS button is lit.
When I press the "Dark" button to restart it, I hear a sound coming from the radio, but the black screen just reappears... Does anyone know how I can fix this problem?
Black display RT4
Black display RT4
JollySpanner
Re: RT4 Citroen c5 2008 Black display.
Unread post by JollySpanner »
Black screen with the orange SOS light is usually the RT4's hard drive failing. Try a forced boot from a genuine RT4 software CD, holding the two white buttons as you switch the ignition on. If that fails, the drive needs replacing with an IDE/PATA type, not SATA or SSD.
