Camshaft sensor removal
Woodford
Unread post by Woodford »
Has anyone had a problem or knows a solution to removing a camshaft sensor from a 2015 Berlingo. Once the torx bolt is removed it won’t slide out because it is too long and there seems no way to manoeuvre it out . TIA
JollySpanner
Re: Camshaft sensor removal
Unread post by JollySpanner »
The bracket above it is the alternator support, and the factory manual removes the alternator and bracket to get this sensor out. Try the EGR pipe first. Unbolt it and bend it aside, which on the 1.6 HDi can give enough room to wiggle the sensor free.
