C3 II (2012–2016) engine swap 1.2 PureTech → 1.4 HDi
FerixNB
Unread post by FerixNB »
Hi everyone,
I'm doing an engine swap on a Citroën C3 II: a 1.4 HDi went into a car that originally had a 1.2 PureTech.
The setup:
- Car (recipient): Citroën C3 II, originally 1.2 PureTech / 1.2 VTi 82 (EB2F)
VIN: VFSCHNZ6GW568778
Engine ECU: Valeo VD46.1 (9813043480)
- Donor: Citroën C3 II 1.4 HDi 70 (8HR / DV4C)
Engine ECU: EDC17C10 (9666729680)
The 1.4 HDi went in with its own engine harness and ECU, and I re-pinned the connector between the body harness and the engine/ECU harness. The engine already starts and runs, and the accelerator pedal works fine.
What I still need are wiring diagrams / pinouts for these three things on the 1.4 HDi:
1. Brake (stop) signal: the brake pedal switch wiring to the engine ECU (and to the BSI, if it goes there too), with pin numbers on the ECU side
2. Alternator: how the alternator connects to the engine ECU / BSI / engine fuse box on the 1.4 HDi (charge signal / control wire)
3. ESP: the connection between the ESP/ABS unit and the engine ECU on the 1.4 HDi (CAN lines or any direct wires, plus the connectors they pass through)
If there are differences between the 1.4 HDi and the 1.2 PureTech wiring for these circuits, that's exactly what I need to know.
Thanks a lot in advance for any help!
x 8172
Re: C3 II (2012–2016) engine swap 1.2 PureTech → 1.4 HDi
I'm afraid I can't help with the diagrams as I only have up to 2012 but hopefully someone with their own access to the Stellantis databases will be able to help. Good luck :)
FerixNB
Hi everyone, a quick update on my C3 II swap (1.2 PureTech → 1.4 HDi DV4C / 8HR).
The brake (stop) signal and the alternator are sorted
Two problems left:
1. Reverse light signal
The 1.2 PureTech had a different gearbox than the 1.4 HDi, and now the reverse light doesn't work. Could someone share the reverse light switch wiring for the 1.4 HDi gearbox? I need the switch connector pinout and where the wires go (BSI, engine fuse box BSM/PSF1, or the engine ECU), plus the connectors in between. If the 1.2 PureTech wiring for this circuit is different, a diagram for both would be ideal.
2. ESP torque fault / coding
The ESP module is showing an engine torque fault, and I can't code it for the DV4C engine. I guess it's still configured for the 1.2 PureTech. Is it possible to re-code this ESP unit for the DV4C (e.g. with Diagbox, and which menu or parameter), or do I need an ESP module from a 1.4 HDi car? If it has to be swapped, which part numbers or versions are compatible? A diagram of the ESP ↔ engine ECU connection (CAN) on the 1.4 HDi would help too, so I can rule out
ESP unit part number: 9817031780
Thanks a lot!
