I am trying to recalibrate the Yaw Sensor on a 2006 Citroen C5 Mk1 facelift 2.0HDI VTR Estate RHR engine. VF7**************[VIN obfuscated, can be read by forum staff].
I had Yaw Sensor internal fault C1310 so I replaced with another Yaw sensor with the same part number.
I have checked the sensor has 12VDC and Ground. I have also checked continuity to pins 25 and 29 on the ABS/ESP MK60 ECU from the Yaw Sensor itself. Both are less than 1 ohm. The Steering sensor is calibrated.
The ESP ECU has comms inactive with ignition on and engine not running. Start the engine and the comms become active.
When I try to use Lexia to initialise the ESP lateral sensor it says "Conditions Not satisfied". Looking on Live Data the Yaw sensor says 10 degrees a second.
Interestingly when I tried to initialise the Yaw Sensor or our 2007 Mk1 facelift 2.2HDI VTX+ it also said "Conditions not satisfied".
My question is what are these conditions?
I was led to believe car pointing straight ahead and engine off. I have tried with both engine on and engine off.
Is there a procedure I should know?
Citroen C5 Mk1 Facelift Yaw Sensor
howardaskew
- x 9
