Hello everyone,
I own a 2010 Citroën C5 X7 Tourer 2.0 HDi, manual transmission, with approximately 245,000 km on the clock.
A few months ago, I was accelerating hard in 2nd gear and briefly reached approximately 5,500 RPM. Shortly afterwards, the yellow Check Engine light came on and the dashboard displayed the message "Anti-pollution system faulty."
Since then, I have been driving the car for approximately 3–4 months without any noticeable problems:
No loss of power.
No unusual smoke.
No unusual engine noises.
Turbo seems to work normally.
Fuel consumption appears unchanged.
The car drives just as it did before the fault appeared.
I recently scanned the car using a cheap ELM327 OBD2 adapter and Car Scanner. These are the codes I found:
P11AA – Air circuit (initially Pending, later Stored after clearing and rescanning).
P1351 – Preheating relay circuit (appears twice, one Stored and one Pending).
Does anyone know what this could be and what is the problem, I have cleared the codes since then, but still have pictures of them,
Thank you
Re: Anti pollution system failed
PaulC5
- x 716
Re: Re: Anti pollution system failed
A link to your similar topic but there were no reasons given by anyone to help viewtopic.php?p=878351#p878351
Now you have deleted the codes have they come back ? If so have a look at the freeze frame data when the last code was stored, it might give an idea what happened. P1351 relates to the glow plugs and most people would ignore it unless you want to replace them and make sure there are no wiring or earth faults.
