my 406 td exec blower only works on full!!, am i doing something wrong with the settings? it just dies when i knock it down from 5 bars to 4. any ideas anyone? thanx
[xx(]
P 2501
gen_ii
PowerLee
Hi
First thing, UNPLUG the fan! You will start to melt the wiring loom if you dont!
Either fix your fans resistor or replace the fan with a good second hand one from the scrappy.
Pop the carpet trim off from below the dash / glovebox, Its held in with 3 x black plastic push rivits, You will see a big black round fan shaped object, Thats it, Now unplug the brown 4 pin connector.
The fan is only held in with 3 or sometime 4 screws & its really easy to remove & refit, Just make sure the ignitions off first!
This fan is fitted to most Peugeots & Citroens so getting a good second hand ones fairly easy.
