Renault Scenic II - Rear Window Issue
welldigger99
Unread post by welldigger99 »
Hi All,
This is a strange one! Rear right hand window partially drops when vehicle ignition is turned off!
Anyone had experience of this, or any clues what could be causing it?
Many thanks.
x 1947
Re: Renault Scenic II - Rear Window Issue
Unread post by Paul-R »
How old is the battery?
Have you tried a system reset? This is the PSA process, I would imagine that Renault would be similar. viewtopic.php?p=601679#p601679
