Peugeout 2008 Adblue Temp sensor (Only one wire)
antonioste
New User
Unread post by antonioste »
I’m having an issue with the AdBlue tank.
I’m getting a "low pressure" error; I’ve taken everything apart and checked every component—everything is fine.
I suspect the problem is the usual temperature sensor.
I bought a 10kΩ NTC thermistor, but my tank only has one pink wire, rather than the typical two wires.
Does anyone know how to connect the sensor?
