406 td flat
chrisndarren
406 td flat
Unread post by chrisndarren »
My new 406 (p reg) seems not to have any kick to the turbo, is it supposed to be that way? please help [:)]
np
Unread post by np »
For a 1.9td it should start pulling from about 1700-2000 rpm,when the turbo starts to work.Below about 1600 rpm it takes a while to pick up.Before i had my Xantia boosted(same engine)it used to start about 1800 rpm,then pulling strongly from about 2100 rpm.
Best thing is do what i did once,as its free.Take another 1 out for a test drive from a garage.If that seems to pull better,you may then want to get it checked out.
Plodder
Unread post by Plodder »
My 406 TD does not have much go below 2000rpm but above it pulls pretty well, even with 172000 miles on the clock.....
