Locating DPF Pressure Sensor
spacebiscuit
x 4
Post by spacebiscuit »
Hi - does anyone know where exactly the DPF Pressure Sensor is located in the engine bay on 2018 DS7? Can it be accessed from above as I lean into the engine bay?
Thank in advance.
x 8151
Re: Locating DPF Pressure Sensor
Post by mickthemaverick »
You need to confirm which engine you have. :)
Steve Walsh
x 518
Post by Steve Walsh »
They are usually located on bulkhead connected to 2 black tubes and a wire, if you cant see it, follow tubes from DPF
spacebiscuit
x 4
1.5 HDi Blue engine.
