Peugeot Partner 2022 (K9) — no OBD communication
Snowerf1
Unread post by Snowerf1 »
Peugeot Partner 2022 (K9) — no OBD communication, no power on pin 16, 12V on pins 3 & 8 ?!
On the cluster is showing all faults, Engine fault, immobilizer fault,abs fault etc etc.
Looking for input from anyone who's dealt with the PSA diagnostic-gateway setup.
Backstory: the car lost all diagnostic-socket communication after a BSI PIN read during a spare-key job. I've since fitted a virginized BSI of the same type. The body side is alive — ignition, indicators, horn and radio all work normally — but the OBD socket is still completely dead (no comms at all).
Measurements at the OBD socket (to ground):
Pin 16 (permanent +12V): 0V — so the scan tool never powers up.
12V on pins 3 and 8, but ignition-switched — it drops to 0V when I turn the ignition off.
Pins 6/14 (CAN-H/CAN-L): open circuit.
So the story is that I have now the immo pin I read out from the ECU with autel im608, but I cannot program a key because I have no power or communication. (I'm starting to wonder if the immo pin read with autel has damaged anything to the ECU) ....I'm completely lost.
Anyone that have some ideas😞😞
x 8165
Re: Peugeot Partner 2022 (K9) — no OBD communication
Here are a couple of links which may help but I suspect you already have this info. :)
https://fixitfrequency.com/obd2-wiring-schematic.html
https://pinoutguide.com/CarElectronics/ ... nout.shtml
Snowerf1
Tried all that
