Peugout 308 2014 engine fault on messages but no engine management light but has service light and airbag light
Protectivedaddy
Unread post by Protectivedaddy »
Car is a peugout 308 2014.
Problem is I get the engine fault requires repair message on console screen but no engine management light. The service light comes on and airbag light and car goes into limp mode.
I don’t have diagnostics yet as waiting for someone to put the scanner on it.
The car sat for a couple of week but drove down to Glasgow no bother it happened while driving back so had a good long run before it happened.
Now on car restart the message pops up with service light and airbag.
Any ideas what it could be. From what I’ve read it could be exhaust related or battery related.
x 8165
Re: Peugout 308 2014 engine fault on messages but no engine management light but has service light and airbag light
It could be a number of things but no point in speculating, wait and see what the fault codes are :)
PaulC5
x 714
Unread post by PaulC5 »
Definitely wait until you have the fault codes so do not spend any money on parts.
With the engine management light not coming on when the engine is running, assuming its bulb is ok, suggests it is not an engine emission problem and with the airbag light not going out it is likely to be related to the air bag system. Note that you will need a scanner that does air bags to check this and cheap ones may not do this. You could have a look under the seats to see if a connector has come undone.
ozfrog
(Donor 2026)
x 84
Unread post by ozfrog »
Sorry for the long story, but
PaulC5 wrote: 02 Nov 2026, 16:38 Definitely wait until you have the fault codes so do not spend any money on parts.
<snip>
I know that your car is not a 406, but I wholeheartedly agree with Paul’s comment about not spending money on parts until you know what is wrong. And don’t even take the word of a dealership.
My first 406 had the airbag light come on soon after I had purchased the car (used). The warranty that came with the car stated that I had to take the car to the dealership for repairs, so that’s what I did.
The scanner said that the driver side seat belt stalk was faulty and needed to be replaced. About $500 Australian. Yikes! At least the warranty was going to pay for that.
About a week later, the airbag light came on again, so back to the dealership. This time it was the passenger side seat belt stalk that was faulty and needed to be replaced. For some reason the passenger side stalk was cheaper - by $5! But again, yikes! But the warranty was going to pay for that.
A week or so later, the airbag light came on again! Back to the dealership. The driver side seat belt stalk was faulty and needed to be replaced.
Hang on a minute. It’s less than a month since you replaced the same thing and now you want to replace it and charge me again?
That’s what the computer says is wrong, so that’s what we have to do to fix the problem.
Can’t you do some fault finding without the computer?
No, the computer says that the seat belt stalk is …
I’ll take my car somewhere else where they can do something without the computer.
But, but …
Five minutes away from the dealership I found a new mechanic who was willing to look at my car without the ‘help’ of the Peugeot computer. A couple of searches showed that the 406 has a very common problem with a connection under the driver’s seat. He looked at the connections, got some new connectors and some wire snippers and he fixed the problem. Ten dollars.
And then I discovered that because he had fixed my car and not the dealership, I wasn’t entitled to claim anything from the warranty.
Cheers,
Andrew
