Hi all,
The heater in our 2017 C4 GP just stopped working. The fans and dual zones work fine, when we up the temp to 'hi' it blows with full force, but no heat.
Is this a common problem with an established fix, or do any of you have some tips for troubleshooting before handing it over to the mechanic?
Alex,
Sweden
C4 GP 2017 heater not working
- x 1498
Re: C4 GP 2017 heater not working
First check is the coolant level - heater is usually first to go if it's low.
Alexsjob
I checked and the level seems fine. Slightly above minimum.
owl
- x 15
It seems known chronic heater blend flap issue. Try manually set for heating. Flap motor is located (for left hand drive, I dont know for rhd) in the driver’s footwell, upside of accelarator pedal or behind the glovebox on the passenger side.
- x 8153
I would suggest that slightly above minimum is not fine. Given that below minimum could result in the engine overheating, hence the scale, then just above minimum suggests adequate for engine cooling but nothing else. Top it up to max and see how it performs then!
Alexsjob
Sorry, but what do you suggest I do with it once located?owl wrote: 01 Nov 2026, 11:34 It seems known chronic heater blend flap issue. Try manually set for heating. Flap motor is located (for left hand drive, I dont know for rhd) in the driver’s footwell, upside of accelarator pedal or behind the glovebox on the passenger side.
owl
- x 15
Take off the electric servo/actuator motor and manually rotate the stub or flap axle with your fingers or a small tool to set it to hot or cold. It is going to be temporary solution. In that case you will not able to use cold air. It means if you have auto A/C set on 21C for example it will be hell hot inside 26CAlexsjob wrote: 01 Nov 2026, 13:59Sorry, but what do you suggest I do with it once located?owl wrote: 01 Nov 2026, 11:34 It seems known chronic heater blend flap issue. Try manually set for heating. Flap motor is located (for left hand drive, I dont know for rhd) in the driver’s footwell, upside of accelarator pedal or behind the glovebox on the passenger side.![]()
As I said temporary solution if it is actuator flap.
Alexsjob
Got it. Thanks.owl wrote: 01 Nov 2026, 15:05Take off the electric servo/actuator motor and manually rotate the stub or flap axle with your fingers or a small tool to set it to hot or cold. It is going to be temporary solution. In that case you will not able to use cold air. It means if you have auto A/C set on 21C for example it will be hell hot inside 26CAlexsjob wrote: 01 Nov 2026, 13:59Sorry, but what do you suggest I do with it once located?owl wrote: 01 Nov 2026, 11:34 It seems known chronic heater blend flap issue. Try manually set for heating. Flap motor is located (for left hand drive, I dont know for rhd) in the driver’s footwell, upside of accelarator pedal or behind the glovebox on the passenger side.![]()
