Moving car when steering wheel lock still on
ben22
Unread post by ben22 »
Hi folks, stupid thing: I went out to move my car (Citroen C1 flair 2018) down a (sloping) driveway and had the fan full on to clear the windscreen. Tried to drive but steering wheel felt stiff as I tried to move out from a bag of something builders had left. Thought the wheel had just stiffened up in the cold so tried to steer, only to realise I hadn't turned the ignition on #-o . Would this have caused any damage?
x 8151
Re: Moving car when steering wheel lock still on
Hello Ben,
I'm not quite sure I understand your situation. You said the fan was running but the ignition was not on. Is that correct? :)
ben22
Yeah, fan was on full for about 30s-1 min to clear the windscreen. I'd thought I'd also turned on the ignition to get the engine running a little, but didn't. When I went to move down the drive the noise of the fan hid the fact the I hadn't started the engine. Hope that makes sense. Basically, if the fan hadn't been so loud, it would have been obvious the engine wasn't running and I wouldn't have tried turning the steering wheel with the lock still on.
x 8151
OK, I wouldn't have thought that you have done any damage, does the steering feel ok now and does the steering lock work when you switch off? :)
x 1944
Unread post by Paul-R »
I also doubt you have damaged anything. Modern cars have such responsive power steering going back to an unassisted car can feel like there's something wrong.
ben22
Thank you both for your help with this. Much appreciated!
Steering's fine. Forty miles there and back from work with no problems, and the steering lock seems okay when engine switched off. Phew!
ben22
Still feel like an idiot, mind.
x 8151
Where are you going to find an idiot at this time of day? :-D
Martin Cheney
x 5
Unread post by Martin Cheney »
Are you sure the steering lock was one, I would think it unlikely that you could get the fan running without at least having ignition at accessory position. More likely steering heavy due to no power assistance…. My guess anyway.
