No Sound after subwoofer install
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
Charmander21
Unread post by Charmander21 »
Hi All,
Vehicle details:
Citroen Dispatch Driver 2020 2.0 BlueHDI, Manual
I beleive this van has the NAC head unit? it has a touch screen with navigation and wired carplay/android auto.
I recently replaced the door speakers and tweeters on my dispatch van, this worked no problem. I also tapped both tweeters (before the crossover) to provide a feed for the sub (Pioneer TS-WX140DA) As I didn't have time to connect the sub at this point I left the cables for the tap unconnected to the sub, and the sub unpowered. At this point everything was functioning fine, audio through all connected speakers.
However at some point when I connected up the sub, to the speaker taps, and attempted to power it on (using a piggyback fuse tap from the cigarette lighter fuse) after restarting the van, I've lost all audio, although the headunit appears to function absolutely fine apart from this.
What I've tried:
> Disconnected the subwoofer from the speaker taps and power.
> Checked all relevant fuses - as far as I know the 20a head unit fuse is the the only fuse for the head unit and amp?
> BSI reset procedure
> head unit reset by holding down the phone key
I have a diagnostic tool but I don't think I can access the audio module.
Is there any thing else I can try? Thank you.
x 8124
Re: No Sound after subwoofer install
When you repkaced the doot speakers did you match the impedance ratings with the originals? :)
Charmander21
The door speakers and tweeters were replaced with alpine SXE-1750S - The impedance is 4Ω and I think that matches the factory speakers. I'm not sure if it was obvious from my post but these were wired in and working fine, it's when I tried to add the sub that something went wrong.
x 8124
Can you draw and post a wiring diagram of how you connected the sub to the tweeter taps? :)
x 1939
Unread post by Paul-R »
Is it a passive or active subwoofer?
Charmander21
Deleted duplicate
Charmander21
It’s an active subwoofer, so takes power from the cigarette lighter tap. It’s fused with a 10a fuse, and grounded on to the chassis.
Here’s my attempt at a diagram:
The sub can take speaker level input, it has a toggle switch to allow switching between rca and speaker level.
x 1939
How do you join the inputs from the two tweeters to the sub?
Charmander21
I’ve used wago 221 connectors, to join to the sub audio input cable. The input cable then slots into the sub with a locking connector.
I was going to solder but wanted to check everything was working first.
Here’s the pioneer wiring diagram:
The difference in line is that rather than wire the speaker output from the head unit, I’ve wired from the tweeters.
Tr7v8
x 4
Unread post by Tr7v8 »
Did you connect the two tweeter connections together. That maybe your problem, I suspect the head unit is not happy having different outputs connected together.
2021 Peugeot Expert L2H1 2.0 Hdi
2019 Abarth 595C
2018 MGS5 Trophy
2018 Mitsubishi Outlander PHEV SOLD
2005 Porsche Cayenne S SOLD
2000 Jeep GC SOLD
2010 Mazda MX5 Mk3.5 SOLD
2000 Porsche Boxster S SOLD
Charmander21
Hmm it’s possible touched them together accidentally yeah. They don’t actually touch as part of the wiring though. Does anyone know how to get audio back? Or would the head unit start up output again if it doesn’t any longer detect a fault?
x 1939
Tr7v8 wrote: 20 Oct 2026, 23:52 Did you connect the two tweeter connections together. That maybe your problem, I suspect the head unit is not happy having different outputs connected together.
That's exactly what I was wondering.
Charmander21
As mentioned I may have accidentally touched the L + R speaker connections together during the install process. But they aren't connected together at the sub, there are separate L and R feeds into the sub.
Anyhow, I've since disconnected all the sub wiring but there's still no sound. I'm guessing I'll need diag-box access to unlock the audio?
