I am new here and hope someone can help me solve this problem I have. I recenlty bought this 2016 Diesel 208, however, it has two problems niggling at me.
Problem 1 - the outside air temp is always showing a negative number which changes with each drive cycle. I purchased a new temp sensor and fitted it to the car now it shows a double dash -- on the screen and reads 215 degrees via the OBD scanner. I believe the wires need swapping but in both scenarios it never read the actual outside temp. Unless I need to reset something or drive but i'm unsure.
Problem 2 - TPMS under-inflated fault- this fault comes and goes when it feels like to wind me up
Upon research I have found this is also related to the outside temp sensor in the mirror. Since swapping the sensor the TPMS/SERVICE light are always now on (possibly need to swap wires).
another finding was that the plug isinde the dorr may need cleaning and reseating, but have not yet taken to door card off to look.
If anyone has any sugestions to the above problems any help will be greatly apriciated.
Craig
