Hi
When I have my xm set to full height the indicator is level with the top line in the sight glass. Does this mean there is a shortage of lhm or too much.
cheers mark
lhm level
tudor
glynn25121100
The LHM level indicator should be between the two red lines not above or below. So if it is sat above the top of the red line then there is too much in, but as yours is level then it is OK. On my Xantia the indicator is half way between the two red lines.
As suggested in an earlier message i read buy yourself a turkey baster and this can be used to remove excess fluid as it sucks up plenty in one go.
Hope this helps.
Glynn
Hope this helps.
Glynn
Mosser
glynn25121100
uhn113x
- x 3
