E-Berlingo 2025 Diagbox
MrProtease
Unread post by MrProtease »
Hi
Can anyone advise whether I can use diagbox with lexia full chip to scan and change parts on an electric berlingo 2025?
PaulC5
x 693
Re: E-Berlingo 2025 Diagbox
Unread post by PaulC5 »
No idea but if you start messing with the car you might void the 3 year warranty and any extended (8 year ?) warranty on the battery.
MrProtease
Thanks for your response PaulC5. This is a cat S I got from copart and doing it up. Therefore, warranty is void as its written off.
Mihael_M
x 37
Unread post by Mihael_M »
For the 2025 Citroën E-Berlingo, you still need Stellantis Diagbox, but the way it operates has fundamentally changed compared to older models.
Ask the AI ​​and you will get a detailed answer:
What program is needed to test the car E-BERLINGO 52KW 2025?
MrProtease
I have been posting on Facebook forums and I've been told that the diagbox 9.277 with a lexia full chip clone can read. I will try this weekend and update the forum.
MrProtease
To update the forum, I was able to scan and clear faults and reset the finger lock on the e berlingo 2025 using lexia full chip clone and offline diagbox 9.277.
x 1939
Unread post by Paul-R »
Thank you for letting us know.
cit-rotti
x 77
Unread post by cit-rotti »
The latest version of Diagbox is 9.278 – software update + activation: €20 at
https://www.guiapsa.com/login
