I have a 2003 Citroën C3 1.4 with an AL4 automatic transmission.
The transmission intermittently starts slipping, and the Sport and Snowflake warning lights come on. After turning the engine off and restarting it, the transmission can sometimes work completely normally again. There are also times when I can drive for about an hour without experiencing any problem at all.
A diagnostic scan reportedly showed “slipping clutch/brake.” However, the mechanic who performed the scan only spent about 5 minutes checking the car and did not inspect the transmission fluid, hydraulic pressure, solenoids, or valve body.
He told me that the transmission definitely needs a complete rebuild, costing around €3,000.
My question is: can a complete transmission rebuild really be diagnosed with certainty from a diagnostic scan alone? Could the same symptoms be caused by pressure problems, pressure-regulating solenoids, the valve body, or another issue that could potentially be repaired for significantly less?
I would especially appreciate an answer from someone with actual experience working on AL4/DP0 transmissions.
What tests would you recommend performing before concluding that a complete rebuild is necessary?
Cintroen c3 al4 2003
- x 8124
Re: Cintroen c3 al4 2003
How many miles has the car done and has the transmission fluid ever been changed?
ozvtr
- x 253
Sounds like the main pressure regulator solenoid if the gearbox works fine after shutting the engine own and restarting.Kakjim23 wrote: 06 Oct 2026, 15:14 The transmission intermittently starts slipping, and the Sport and Snowflake warning lights come on. After turning the engine off and restarting it, the transmission can sometimes work completely normally again. There are also times when I can drive for about an hour without experiencing any problem at all.
There are three clutch packs and two brake bands. Which one is slipping? Its a rhetorical question.
The main pressure regulator is cheap and relatively easy to replace. It's the cause of a lot of AL4 failures. I would replace that and definitely change the fluid.Kakjim23 wrote: 06 Oct 2026, 15:14 Could the same symptoms be caused by pressure problems, pressure-regulating solenoids, the valve body, or another issue that could potentially be repaired for significantly less?
The AL4 is very compact and you need to literally pull the gearbox apart to get to anything! So while you are in there you would change the friction plates, seals and bands.Kakjim23 wrote: 06 Oct 2026, 15:14 What tests would you recommend performing before concluding that a complete rebuild is necessary?
Another failure mode is that the brake band friction material can wear down and expose a rivet on the band causing the rivet to ride on the planetary gear drum instead of locking the drum. This also damages the drum!
