DS3 too much oil passes through pcv valve?
Roman11
Unread post by Roman11 »
Got this much oil pooling here after a short journey. I did replace pcv valve membrane and spring to see if it fixes but still no luck
x 8121
Re: DS3 too much oil passes through pcv valve?
Are you using the manufacturer's recommended oil in the engine? That issue can occur when the oil is too thin!! :)
Roman11
mickthemaverick wrote: 27 Sep 2026, 10:47 Are you using the manufacturer's recommended oil in the engine? That issue can occur when the oil is too thin!! :)
Yes as recommended by the book 0w30 total quartz ineo first.
x 8121
As far as I can see it seems both 0-30 and 5-30 are recommended for your engine. I'd suggest the difference being average ambient temperatures where the car is used. If I'm right then I would suggest 5-30 is right for UK climate so that may be the reason for your apparent excessive evaporation. Only my reasoning with no expert knowledge to back it up! :)
