Hi all.
Where do i spray the cleaning foam can into DPF to help clean it?
Do i remove the nut at the metal pipe end on the DPF cannister or just unplug the rubber pipe from metal pipe and spray that way into metal pipe?
My DPF is 75 percent full although it does regen but it only lasts couple weeks.
5008 mk1 2.0 hdi DPF cleaning
PaulC5
- x 676
Re: 5008 mk1 2.0 hdi DPF cleaning
This topic on cleaning the dpf on a Nemo might help. To clean the dpf properly it needs removing. viewtopic.php?p=868207&hilit=nemo+dpf#p868207
