The black things on the backrest are the two lumbar support air chambers. The one on the side bolster is also a chamber. The pouch to the lower right corner houses a single compressor and what I believe a valve body, which directs the air supplied by the compressor to the three hoses (red, green, black). One hose (IIRC red) inflates the upper chamber, one inflates the lower one, and the third inflates the side bolsters. So no separate "pumps" involved. Any adjustment on the supports activates the compressor and the relevant valve, which allows separate adjustment of lower and upper back supports, as well as side bolsters.
I'm not sure if Series 2 has the side bolsters (maybe Activa does?) because I think Series 2 comes with side airbags, which might have made side bolsters impossible to integrate. This is a Series 1. Series 1 owners die like real men. In style and comfort.
