Total Fluide T for C Max auto transmission
citroencxsteve64
x 4
Unread post by citroencxsteve64 »
Trying to get hold of some to change fluid in C matic for Citroen Cx 2.5 GTi 1987. The nearest I can see is around 3 and a half hours away and no-one seems to send it by courier. I'm in Warrington, does anyone have any suggestions where I can get some closer to home or an alternative to it??
Thanks guys.
x 8083
Re: Total Fluide T for C Max auto transmission
I would contact Opie Oils and see if they can help: :)
https://www.opieoils.co.uk/c-1432-atf-a ... =36%2c1461
x 1998
Unread post by Stickyfinger »
https://www.ebay.co.uk/itm/165980367991
So cheap you could corner the market. Having looked at a few of the "leading" classic parts suppliers for old Citroens and their prices (WoW ! LOL) maybe you should ....
aerodynamica
x 215
Unread post by aerodynamica »
Please check that you're searching for the correct fluid! The CX 25 GTi never used Fluide T. Only the 1977-1980 CX 2400 and 2200 cars with C-Matic semi automatic transmission used this stuff. If you have a mid 80s CX auto then it will be standard ATF dexron fluid.
Graeme M
x 1998
Dexron = ALWAYS use the recommended type, never believe the "Is compatible with" line often stated on later types.
citroencxsteve64
x 4
Nice one 👍
