5008 I timing chain
Pau
New User
5008 I timing chain
Unread post by Pau »
I got a timing error code, and did the timing procedure after a splendid YouTube instruction, where I discovered that the camshaft gears had lost position, even though a certified Peugeot workshop had changed the chain at 60000 km! Worked fine but now the chain is making a rattling noise so the chain must be changed again! The only problem for doing it myself is the awkward position of the chain tensioner on the back of the engine with very little space for a proper tool, without taking out the engine! Any hints to solve this? :?: :roll:
x 8119
Re: 5008 I timing chain
What mileage have you done since the chain change? :)
PaulC5
x 682
Unread post by PaulC5 »
What engine is it ?
