Hello,
I've written here about my issues with a cheap O2 sensor.
I've since replaced it and the car runs fine, apart from a sometimes lumpy idle and pops and bangs from the exhaust when engine breaking when the engine is cold (LONGFT% is always around 25)
I have noticed a crack at the O2 sensor hole, could it be the cause of the issues? I'm only wondering because the crack looks quite small
Citroen C2 1.4i exhaust manifold crack
- x 8082
Re: Citroen C2 1.4i exhaust manifold crack
It could have a bearing. Try a temporary repair that won't last long but at least it might confirm the crack is your problem. Ideally get it welded but if that's not possible you could try a metal filler to see if it improves things, something like this:
https://www.ebay.co.uk/itm/314958082646
- x 1066
Good old 'chemical metal' works on everything, just don't put it anywhere you don't want it including threads
Champion of Where's CitroJim
OneRandomBX
Just ordered some exhaust sealing paste, my only worry is that there may be more cracks where I can't see them
Good news is that I found a used manifold for only 30 euro, if it's crack-free I'll buy it and swap it over the weekend
I just hope my manifold isn't seized too bad...
ozvtr
- x 244
The fuel trim is maxed out! That explains the popping and farting on deceleration. I'm not sure that crack is wholly responsible. Yes, it could suck air in through that hole and upset the O2 sensor. Of course replacing the manifold wont hurt. The paste will quickly tell you if that crack is your only problem.
The manifold should come off without any problems. However, all the nuts might not come off the studs. The studs and nuts may come off as one. Separating the nuts from the studs is not easy...but not impossible. Lock two spare nuts back-to-back onto the 'other' end of the stud. Remove the 'stuck' nut, then unlock the two nuts.
What engine ECU does the car have? What scan tool are you using? I can not get LEXIA to read the long term fuel trims on my TU3JP engine with a SAGEM ECU. Only the short term, which is not very helpful.
OneRandomBX
Not sure about the engine ECU
I've tried listening all around the intake manifold side using a bit of garden hose, couldn't find any suspicious hissing noises that would indicate an intake leak
I'm using a cheap OBD scanner I got from Temu for 10 euros
The exhaust putty is coming tomorrow, I'll have an update then
I have another concern though, when the oil filler cap is off while the engine is running it's blowing more air than I would expect
Not quite enough to blow the cap away but there is a significant amount of pressure and, I'm guessing, oil vapors
Anyone with experience with this engine that can tell me if this is normal?
- x 1996
Chemical metal WILL BURN OFF.....100% pointless IMHO.
That crack will grow, they nearly always do in cast iron. It needs it end drilling (to halt its growth), the crack "V" cut fully through then welded with the correct bronze filled rod (after pre-heating) on a pre heated manifold. Not complicated.
- x 8082
Indeed it will Alasdair which is why i said: "Try a temporary repair that won't last long". The point was to block the crack for a quick test run to see if the problem is cured, not a long term fix.
ozvtr
- x 244
What are the short term trims like at idle?OneRandomBX wrote: 08 Sep 2026, 10:51 I've tried listening all around the intake manifold side using a bit of garden hose, couldn't find any suspicious hissing noises that would indicate an intake leak
The ELM327 based scanners are cheap but provide a lot of data about engine performance. My son has one, I might borrow it and see what it says.
There is a fair bit of blow by in my engine, but I would consider the engine to be "normal" for 200,000Kms. I have done compression tests and the results ranged from very good to poor (not bad, just poor). However, performance is "OK" (for a little 1.4 engine) and oil consumption is still what I would consider very good (about 1L per 10,000km).OneRandomBX wrote: 08 Sep 2026, 10:51 I have another concern though, when the oil filler cap is off while the engine is running it's blowing more air than I would expect
The danger you face is oil dilution. Continued high fuel ratios will find fuel getting mixed with oil on the walls of the cylinders and reducing the effectiveness of the oil to lubricate.
OneRandomBX
Well I have some disappointing news
I plugged up the crack last night, laying the paste pretty thick to make sure no air could leak
Drove to town and back this morning, around 7-8 km round trip, and I could still hear popping from the exhaust
Plugged in the scanner when I came back and the long term trim was around 32!
Short term trim is usually less than 5
Where do I go from here? Check for intake leaks? The exhaust manifold could be cracked somewhere where I can't see?
ozvtr
- x 244
That's odd. Vacuum leaks typically manifest themselves at low RPM. So I would expect short term fuel trims to be high and long term to be normal(ish). But you are getting the opposite! And if you don't have any idle problems the problem is probably not on the inlet side.OneRandomBX wrote: 10 Sep 2026, 07:05 Plugged in the scanner when I came back and the long term trim was around 32!
Could still be an exhaust manifold problem. Is the exhaust gasket intact?
Have you looked at the electrodes of the spark plugs? Any difference between the look of any of the 'plugs?
Seeing as you are replacing the exhaust manifold anyway, I would wait until you have removed the old manifold and studied the situation before making any other assumptions.
