Accumulator sphere
John F
Accumulator sphere
Hi, having successfully changed the rear spheres on my Xantia 2 following advice from members and reading past posts; the operation was so easy compared with changing the fronts, no having to hit the sphere to "break" the thread, no extension pipes on the sphere tool, no nothing. This week end I attempted the accumulator sphere and couldn't budge it, even with a 24" steel pipe on the sphere tool handle. What does the sphere fit on to and will it cause any damage if I increase the leverage with a longer extension tube? I have read as many old/archivied posts as I can but only have a very small blow lamp for plumbing work and am very hesitant to start trying to thump the sphere to shake the thread or chisel it off because of the radiator being so close. Is there a picture/sketch/ diagram that will help me decide the best course of action; and as before, any suggestion from members will be greatly appreciated.
John F
Homer
- x 16
The only one I ever replaced I did with the pressure regulator so I removed both together.
I separated them afterwards as the place I got the sphere from wanted my old one and they came apart quite easily.
I would imaging access being the biggest problem doing it on the car.
Removing the regulator isn't that difficult and could save you some scraped knuckles.
TheWorker
