NG4 Navidrive 3D Wip Com 3D - HDD Image
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
5mapa5
Unread post by 5mapa5 »
Hello everyone,
I am looking for a working HDD image for an NG4 or Wip Com 3D unit.
I have a unit that is stuck in a bootloop, meaning it only displays the message that a system check is being carried out and that you should not turn off the engine for at least 25 minutes. However, this message doesn't go away anymore, not even after a long drive. Nor does it go away after disconnecting the battery, pulling the fuse, using the key combination 1, 3, 5, or CD eject and Mute...
I think the HDD has crashed or parts of the partition are damaged. Therefore, I want to install a new HDD or CF card, but for that, I need a working image with the 4 partitions. I think cloning my HDD won't do any good, since the cloned file would then have the same errors...
I would be very grateful if someone had this file or could create it and make it available to me. I really want to get the device working again!
Thanks and best regards from Hamburg #-o
x 8077
Re: NG4 Navidrive 3D Wip Com 3D - HDD Image
As you have had no response so far I am posting simply to bring this onto the top of the unread topics list where many members conduct their browsing from. Hopefully it may inspire a response from someone who can help!! Good luck :)
x 1931
Unread post by Paul-R »
Yes Mick, I had missed this.
@5mapa5 Your best bet is to read the (long) thread immediately above this post. I think this is your only hope.
viewtopic.php?t=57430
